Totalnoob Posted June 15, 2015 Report Share Posted June 15, 2015 Does anyone know if a 2 channel amp when using it as a 2 channel amp and not a bass amp if the amps subsonic filter works for the speakers i have hooked up? or does the amp need to be bridged for the subsonic to work? i am just curious because i currently have it off at 10hz. Link to comment Share on other sites More sharing options...
81000D Posted June 15, 2015 Report Share Posted June 15, 2015 If you are using it for your door speakers then I would set it around 55-60hrz bro. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 15, 2015 Report Share Posted June 15, 2015 what amp? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
_paralyzed_ Posted June 15, 2015 Report Share Posted June 15, 2015 It's active both bridged and as a 2 channel. Link to comment Share on other sites More sharing options...
firebirdude Posted June 15, 2015 Report Share Posted June 15, 2015 Depends on the amp. Many 2-channel amps don't even have both a LPF and HPF. If yours is selectable with a switch between the two (and full), then yes, it's active at all times. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 15, 2015 Report Share Posted June 15, 2015 It's active both bridged and as a 2 channel. your answer didn't make sense until I realized I read the question wrong! Oops...mah bad. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
