Moreno93 Posted June 18, 2015 Report Share Posted June 18, 2015 First one is pertaining to what is a better place to connect my 1/0 wire. First option directly to the battery. & second option is a red box that is connected to the battery & is where the alternator sends its power to the battery. I've up until now always used this redbox to get power to my amps, but im starting to wonder if it makes a difference between there & the battery. I ask this now because i'm doing a run of wire and don't want to cut it and then find out it should be the other option and have to redo it because it wasn't done correctly first. Pic's to follow Second one is regarding the box's that i plan to use. I was going to do two separate ported box's tuned to 35hz with about .7 cft of volume after displacement. (DC Audio M3 8") But is this a bad idea? Im just wondering if there could be noises added in from the subs not being in the same box.. Any idea's? Link to comment Share on other sites More sharing options...
_paralyzed_ Posted June 18, 2015 Report Share Posted June 18, 2015 To the battery. Two boxes is fine. Link to comment Share on other sites More sharing options...
Moreno93 Posted June 18, 2015 Author Report Share Posted June 18, 2015 To the battery. Two boxes is fine. Thanks! Link to comment Share on other sites More sharing options...
