still don't know what the hell it is
Rpm rise and drop after big 3. Disconnected the 1/0 run from the Alt to the battery. Runs fine for a minute then up and down goes the rpms.. Just stalled out again. Did this yesterday with original grounds and upgraded alternator power run.I need help before it gets dark.
Your pcm gets reset and will take a minute of running to get a stable idle.
If it has been longer than that then start checking around and see what you accidentally knocked loose, like a vacuum line or plug.
EDIT: Make sure you check all plugs in the event you pulled one off so you could route the wire.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
now it's running fine. If I tap the gas , it's drops after the rpms come down. Dont think I worked near any vacuum lines. It ran perfectly fine until I started this big 3. So let it run awhile and it reset itself?
what kind of car/truck??
I have done a few batteries and alts on some chevys in my job and when we restart we end up having idle problems. After cleaning throttle body truck runs good. Found out that the ECU would loose memory and dirty throttle body would give a little problems.
If it's worth building, it's worth over building.
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
