JuniorXJ Posted June 28, 2015 Report Posted June 28, 2015 Need help with design of a box for 18" Fi BL. I want sub up , double baffle and port back. but im open to suggestions if there is a better configuration. it will be installed into my 98 Cherokee Sport, I have 36" left to right , 23 1/2" front to back, and 24"to 26" high. It will be powered off my CT Sounds 1400.1 wired @ 1ohm. 1998 Jeep Cherokee Headunit: Alpine CDE-143BTEq: NVX XEQ7Front stage: Boston Acoustic 6.5 Component setRear stage : RemovedMid/High Amp : Pioneer GM-X364 70x2 bridgedSubwoofer: Fi BL 18" Dual 2 wired @ 1ohmSub Amp: CT Sounds 1400.1d Build: http://www.stevemeadedesigns.com/board/topic/180586-juniorxjs-98-cherokee-build/
Joe X Posted June 28, 2015 Report Posted June 28, 2015 Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 5", figure is just an assembly guide:
