box for two 10 s
will a 6" aeroport be too much for a 3cf box with two infinity 10"subs that have a xmax of 13mm?
is making a L shaped box a bad idea compared to a regular box? I just want to use the empty gap between my rear seats and the box because of the steep angle of my rear seats. thank you
You can use both options, if you want a slanted baffle you may want to fire the port sideways.
To have everything firing back the 6" port would need to bend and still may not fit, likely the case if you want to tune low, much more practical would be a slot port which will work nice as well, but yes, a 6" would work if you can fit properly.
  • Who's Online   1 Member, 0 Anonymous, 564 Guests (See full list)
