sundown e 15 box help
I have another friend who wants me to build him a box for a sundown e 15. It will be going in the trunk of a Toyota Camry. I think it would have to be sub up, port back due to the trunk opening. Im thinking 3 cubic feet tuned to 35hz. could i get a design please? hate seeing good subs go into prefabs when i can build them a better box for cheaper. Thanks for the help!
and i can get max dimensions soon once he is off of work.
Fi Team 18's (4)
Crossfire 16k
Crossfire 400.4 & 800.4
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
post dimensions and amplifier he will be using (rms power)
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
If there is anyway you can avoid facing the sub up, it would be best for you to do so. Subs up in trunk car are just a recipe for trunk rattle, which is just wasted energy that would otherwise be bass.
Builds:
Max dimensions are: 18" height 18" deep 36 wide
He said the amp is a crap 1000 watt amp but putting out about 300 watts. And wants to upgrade to a 500 watt punch amp later on.
Fi Team 18's (4)
Crossfire 16k
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
See if this can fit, if not it can be changed, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   1 Member, 0 Anonymous, 1566 Guests (See full list)
