less than 33.5. sorry i forgot to post it before :blush:
what program do you use for port and tuning calculations?
i think that's what i'm using too, i think it came out at 32hz on mine when i put up all the dimensions
i think amatt had one up for download up here too. probably takes different things into consideration with the calculations in the boxes. wood displacement...sub displacement, port/wood displacement. 1 hz wont make a difference really. hell it coulda been 32 hz before i posted...i just remember seeing 33 as the last number i saw heheh
as in flush mounting it? only real benefit is the sweet look it gives :P it can also act as a double baffle and help prevent vibrations from the sub
If it's for SPL do 4 cubes before displacement, 2 6" aeroports.
For music, go DD spec - 4-5 cubes, 16" of port area per cube of box, 15-16" long port. Gives tuning of around 40hz but because the 95 is very stiff it will play lower pretty happily.
I played music with my 9515 in an SPL box tuned to around 55hz and it still hit the lows ok...
Sinking your sub in can give very small gains in SPL because of smoother airflow around the sub.... mostly it's just for looks though :)
Edited by Boon
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 4000 Guests (See full list)
