Help Building a Box: 2 Hertz HX300D's
Ric_Moon
Hey everyone, I would appreciate any help building a box for 2 12" Hertz HX300D subwoofers. I have a Lincoln MKS with plenty of trunk space, but Hertz recommends smaller boxes. I listen mostly to rock/metal/classic rock, and rap. If I had to guess, I'd say 60% rock, 40% rap. My understanding is that ported boxes will hit harder with rap, but I will lose some sq overall.
Should I go with ported, sealed, or try a t line box? Also, what dimensions should I use? Hertz recommends anywhere between .77 and 1.35 cubic feet for 1 sub. So if I have 2, should I just double that number? They also recommend using 1" of Fonoform on all walls except for the driver wall. Is that something I should definitely include?
I appreciate any help on this, I have done a lot of research and this forum comes up the most. Thanks in advance!
Ported boxes don't necessarily have lower SQ than sealed boxes do, in fact they can have better SQ properties if designed to do so.
With those subs I would recommend a ported box. I haven't crunched the numbers to see what size box would be best, but 1.35 cu feet sounds a bit on the small side.
As far as the Fonoform goes, I wouldn't bother with a ported box.
Builds:
Thanks! How should I determine the right size? I downloaded WinISD 0.44, but it didn't have the HX300D listed, so I created it and used the info from Hertz' website. I left a couple of fields blank since I didn't know what to put.
The HX300 model pretty nice at 1.4 net @34Hz but 1.75 net would give you more efficiency while sacrificing very little sound quality:
1.4 net @ 34Hz:
1.75 net @ 34Hz:
Group delay for both:
If you are not going to overpower the subs maybe 1.75 net ported would be a nice choice for a little more output, sound quality will stay good in either case.
Joe X. I must have looked at about 6 or 7 Hertz threads on this forum before signing up, and you posted in all of them lol. You're awesome, I appreciate it. So for 2 subs, how many cubic ft should my box be?
Edit- I will be powering the pair of subs with a JL 1000/1v1 monoblock amp.
Yes 1.75 net It looks a good compromise between sound quality and output, you gain like 2dB without compromising quality.
  • Who's Online   0 Members, 0 Anonymous, 3349 Guests (See full list)
