2 Pairs of Component speaker set on 2 channel Amp?
Hi,
Well i've a question , I'll appreciate if you guys assist me in this matter .
which one is warm sounding speakers ?
Hertz hsk 165 component
or
Audison Voce AV K6
or
Focal Performance PS165
or
DLS UP 6i
or
Helix
thnx
yes, you can hook both pair up, one pair per channel...just keep in mind the amp will see a 2 ohm load, so just be careful with the gain settings.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
oh...and, welcome! :WELCOME:
Singer 220 amp alt
Thankss for quick reply ,, well if I put gain to "ZERO" .. I think it would work .. isn't it ?
you want to have your gains set properly. An o-scope, or what I use, a DD-1, is the fastest and easiest way to get set up correct. A DD-1 costs 150 bucks, well worth it in my opinion. Or you can always look on the tool map and see if there is someone close to you that you can use. And there is always the classifieds to find a used one.
Singer 220 amp alt
Yes you can hook them up but you need to know what your frequency range is. Som 2ch amps dont do the high frequency
You need trunk space to get groceries and shit...bitches love groceries
