Wehan Posted August 22, 2015 Report Posted August 22, 2015 OK, I got a pair (+/-) Knu battery terminals, these, and a pair of set screw terminals, these. The positive is fine, but the negative one is as tight as I dare go without stripping the block but the ring terminal can be moved back and forth by hand with a little force. Is this a good connection or should I look for different terminals? the block is a high polish so its smooth as glass and the way they are both shaped the + terminal and ring terminal are form fitted so that's why I cant get the + side to move but the - side has to be oriented in a way that I have to flip over the ring terminal to the non form fitted side so that's why it moves around, otherwise it would feel as solid as the + side but is it really any good?
Mr DeeBeez Posted August 22, 2015 Report Posted August 22, 2015 I wouldn't trust a connection that I could move around easily. Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
