Box spec and ideas 2-10 xfl 1044 in 02 mustang gt
Willydsm
Hello , new to the forum here, decided to come to the best for some help.
Need some box specs and possible design help,
2-10 ab xfl 1044 subs on a 120.1 ab amp , trying to get a box built for an 02 mustang gt , my friend is a carpenter , and i have built boxes , but this is seeming quite difficult with the room i am givien
Also should i build the box to face out back seat or sub towards trunk? Im looking for spl, any help would be very much appreciated, thank you
Here is a suggestion, need to verify the suggested dimensions will work, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide, bracing is 1" wooden dowel rods:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Specs on subs
Imp (Ohm) 2x4
Rdc (ohm) 1.7
Levc mH 2.194
Fo Hz 32.4
Sd msqM 33.01
BL TM 13.991
Qms 3.628
Qes 0.447
Qts 0.398
n% 0.478
SPL dB 87.6
Vas L 17.6
Cms uM/N 109
Mms g 229.2
VC Inch 3
Mgnt oz 220
Xmax ±MM 19
RMS 1000W
MAX 2000W
F.Range Hz <300
Mounting Depth
MM 181
Inch 7.13
  • Who's Online   0 Members, 0 Anonymous, 735 Guests (See full list)
