boom50cal Posted August 31, 2015 Report Posted August 31, 2015 duramax? factory dual bracket ftw. edit, I'd run a 2k on stock charging with two nice batts in a heartbeat. I did it for several months in OK's hot ass summer with no real problems. just gotta pay attention. O'Reilly's has some nice duralast platinum AGM's that aren't too expensive. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
tyma1026 Posted September 1, 2015 Report Posted September 1, 2015 You have the battery current sensor. And if I remember righr you have the small sensor. You can maybe add a slightly bigger cable but I doubt you can add more cables. I could not find specific details about your truck but I have an 07 Cadillac DTS and I was able to fit 1/0 cable through the current sensor for my ground. I believe it was either knu 1/0 or Stinger. I'll have to check but it was a tight fit. The factory wiring was 2ga iirc Anyways, hopefully you have a similar setup and can add 1 run of 1/0 as I did.
