brian85578 Posted August 27, 2015 Report Posted August 27, 2015 Do u guys leave screws in box pieces after glue is dry and if so how do u counter sink screws so u can fill holes
dsw422 Posted August 27, 2015 Report Posted August 27, 2015 you can get either a counter sink bit or buy a set of drill bits with adjustable depth countersinks (also called screw pilot bits) ... you countersink before you place screws.. http://www.homedepot.com/b/Tools-Hardware-Power-Tool-Accessories-Drill-Bits/Countersink/N-5yc1vZc248Z1z0y9n0?Ns=P_REP_PRC_MODE%7C0 heres a cheap set.. almost like the one i have... http://www.harborfreight.com/22-piece-carbon-steel-tapered-drill-bit-and-countersink-set-7608.html 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
RooTxBeeR Posted August 27, 2015 Report Posted August 27, 2015 Easiest way, take a drill bit the size of your screw head, and just punch in a little, then get a small bit smaller than the actual screw and drill into that little whole. Countersink without the expensive countersink bit. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
