There are three companies I would buy an alternative from and neither of those are one of them.
DC power inc, mechman, or singer.
Copied from the first link, lmao.
400a of alt for 100a stereo, holy shit.
For example, if your audio system demands an average of 100A, and if your basic vehicle electrical load is, say, 64A (typically 80% of your stock vehicle alternator's rated output), and you have installed a 200AH battery bank, you will need an alternator that can supply at least 300A.
This assumes that you drive at average engine speeds sufficient to produce full power from the alternator. However, average engine speed may not be sufficient to generate full alternator power. In this case, an even larger alternator should be fitted to properly supply the electrical system. In a low engine speed situation like this, to supply your average electrical demand, it might be necessary to install a 400A alternator!
  • Who's Online   1 Member, 0 Anonymous, 409 Guests (See full list)
