la_01ninja Posted September 1, 2015 Report Posted September 1, 2015 Hey guys, need some help here. Buddy of mine just gave me 2 Kenwood KFC-W3013PS 12's. I need a ported box design/ cut list.. Will be going into a 2001 Mitsubishi Galant... Space is limited to 32 wide, 16 high, and 36 deep.The speaker specs are Nominal Impedance 4 Ω DC Resistance 3.4 Ω Voice Coil Inductance (mH) 1.65 Piston Area (Sd) 0.051 Force Factor (Bl) 10.5 Volume Acoustic Compliance (Vas) 83.7 liters (2.956 cu. ft.) Moving Mass (Mms) 183 g Resonance Frequency (Fs) 25 Hz Mechanical Q Factor (Qms) 8.250 Electrical Q Factor (Qes) 0.910 Total Q Factor (Qts) 0.820 Maximum Peak Power 1,200 W Peak Excursion (Xmax) 15.1 mm Displacement 2,155 cc (0.072 cu. ft.) Mounting Depth 6 in (153mm) Weight of Magnet 1,780 g Voice Coil Diameter 65 mm They also recommend 2cu ft each Any help would be appreciated... Thnx
Joe X Posted September 1, 2015 Report Posted September 1, 2015 So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
la_01ninja Posted September 1, 2015 Author Report Posted September 1, 2015 Thanx for the design.... I'm gonna run them off of a Precision Power DCX-500.1. Underpowered for now. More upgrades coming but slowly...
la_01ninja Posted November 22, 2015 Author Report Posted November 22, 2015 OK so the Kenwoods didn't last long so now the wife bought me a Soundqubdd HDS215.... So with the same amount of room I posted above, would it be possible for someone to get me a design/ cutlist for this 15??? Here are sub specs... Model HDS215 Woofer Size 15" F(s) 36.34 Hz R(e) 7.47 Ohms Z(max) 69.87 Ohms Q(ms) 7.483 Q(es) 0.895 Q(ts) 0.800 V(as) 73.3100 liters (2.589^ft) L(e) 8.41 mH n(0) 0.37% M(ms) 269.40 grams C(ms) 0.07 mm/N Sensitivity 1W/1m 87.84 1W/1m BL 22.65 Xmax 13.25mm Magnet Weight 100oz Coil Diameter 2.5" Coil Length 40mm Usable Throw 26.5mm RMS Power 600W Peak Power 1200W Mounting Depth 7.5" Circle Cutout 13.875" Outer Diameter W/Gasket 15.1875"
Joe X Posted November 22, 2015 Report Posted November 22, 2015 So here is a suggestion for the HDS215, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
MotorCityFats13 Posted November 22, 2015 Report Posted November 22, 2015 OK so the Kenwoods didn't last long what? did not last long?
Joe X Posted November 22, 2015 Report Posted November 22, 2015 You are the man joe Glad to help, it would be best if you did a HDS315 instead as the RMS power handling of this sub is less than the combined power handlingof the kenwoods. If you'd like that I'd need to change the above a little, let me know.
la_01ninja Posted November 22, 2015 Author Report Posted November 22, 2015 OK so the Kenwoods didn't last longwhat? did not last long? Yea.... They were used and free and I had no idea how they played them... Needless to say, I was playing some decaf and they started smoking.....
la_01ninja Posted November 22, 2015 Author Report Posted November 22, 2015 You are the man joe Glad to help, it would be best if you did a HDS315 instead as the RMS power handling of this sub is less than the combined power handlingof the kenwoods. If you'd like that I'd need to change the above a little, let me know. Probably in a few months when I convince the wife to upgrade. I really do appreciate you input!!!
