Think i can get the 150db?
sbg
how did the metering go?
Not good. Was disappointed. But time for a new box and some other stuff to fix the problem. Its loud to the ear just not the meter. 145.9db @ 37hz
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Hell yeah, get another box in there. Good luck on this quest. You've got enough equipment(when you get a bigger amp) to get that number.
ThIs 145.9 is with my Orion xtr3700.1
Rated 3700rms at 12ohm 12.6v
Yes put a bigger brace in the port. I just think this box bmdont work for this sub. One of them things, it's a custom built sub so was not sure what it would like... I'm sure it will take a few boxs and some deadner, as I have a lot of roof/gate flex
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I am thinking one big round port for the next box, like a 12" sono tune haha
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I have seen crazy things work. A box not quite so tall would be something I'd look into doing if you can.
Also in my plan. I have about 5" I can drop. If I take the plastic floor out.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Box is way too big and choking that airflow A LOT, try a real burp box brotha, did you remove the back seat? if that´s the case, i would try sub forward/port back
If you have the back seat in, i would do about 4 c/f and 3 6" full lenght aeros (17" long each) , that should get you a few dbs louder before adding the power you want to add :)
I'm not going for burp setup. I like my music. This box does suck tho. I need to talk to someone who has built in a HHR before so I know what way to turn this build. As it is now I know nothing about what the car like a aside from my peak is 37hz
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 3085 Guests (See full list)
