412Mark Posted September 24, 2015 Report Posted September 24, 2015 I am working on a box 6 cubes 108 square inches of port. I was seeing if anyone knows of could figure out the port length to tune the box at 34 hertz. I tried to download Torres but I am having problems getting it on my computer
Frank H Posted September 24, 2015 Report Posted September 24, 2015 Have you tried downloading an app? BTC (box tune calculator) or Ultimate Car Audio App? about 35 inches if your 6 cubes is net Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
412Mark Posted September 24, 2015 Author Report Posted September 24, 2015 My 6 is net at least that is what I am shooting for. 35 sounds long. I looked up those apps and I could not find them
Frank H Posted September 24, 2015 Report Posted September 24, 2015 Is it a slot port? Can you give me dimensions of box and Ill punch em in the other app. According to BTC (box tune calculator on android) : 33 inches is 34.15hz35 inches is 33.36hz Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
MotorCityFats13 Posted September 24, 2015 Report Posted September 24, 2015 exact lengths 33.37 for a square port @34hz 28.17 for a slot port @34hz unless you measure your cuts with digital caliper's go with these measurements square port of 33.25" is 34.05hz slot port of 28" is 34.03hz the amount away from 34hz will be negligible I used this web calculator http://www.carstereo.com/help/Articles.cfm?id=31
Frank H Posted September 24, 2015 Report Posted September 24, 2015 I hadnt realized that a square port needs to be longer than a slot port. Care to explain? Id think the square would be more efficient and require less length. Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
Triticum Agricolam Posted September 24, 2015 Report Posted September 24, 2015 I hadnt realized that a square port needs to be longer than a slot port. Care to explain? Id think the square would be more efficient and require less length. You are correct in that a square port is more efficient than a slot port of equal area, however efficiency has nothing to do with tuning frequency. Since slot ports usually share common walls with the rest of the box, this makes them perform like they are longer than the really are, and thus they can be slightly shorter. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
412Mark Posted September 24, 2015 Author Report Posted September 24, 2015 The port will be using two common walls with the enclosure. So I guess slot port then.
412Mark Posted September 24, 2015 Author Report Posted September 24, 2015 I have an iPhone so that explains why I couldn't find that BTC app
Frank H Posted September 24, 2015 Report Posted September 24, 2015 Thanks for the explanation. Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
