Lakeshow94 Posted October 2, 2015 Report Posted October 2, 2015 Getting a zapco z-3kd soon. Only running that and a t400-4 (60 x4 @ 4 ohm). Currently I have one run of stingers better 0g going back to the trunk. I wanted to use 0g going into the zapco instead of 4g. Does anyone know of a fused dist block that does that? How else would I go about doing this? Use the rear battery as a distribution block and fuse after? 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Clownrock95 Posted October 2, 2015 Report Posted October 2, 2015 Do you mean a fused d-block with 1 0ga in and 1 4ga out and 1 0ga out if so I would suggest doing what Meade did on the front of his trailer (he modify a fuse in the inverter video) iwould link it but I'm at work and on mobile
Wehan Posted October 2, 2015 Report Posted October 2, 2015 Knukonceptz has one with dual 1/0 in and then dual 4ga and a single 1/0 out, all 3 fused with mini anl. http://www.knukonceptz.com/mobile-audio/distribution-fuse-blocks/sp/konfused-3-way-fuse-or-ground-distribution-block-/
Lakeshow94 Posted October 2, 2015 Author Report Posted October 2, 2015 I'll look into that video. My issue with the knukonceptz one is the mini anl. I think the z-3kd will pop those all day. Isn't the max amperage 150-175? 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
FknCrawler Posted October 2, 2015 Report Posted October 2, 2015 http://www.droppinhzcaraudio.com/toolmaker-custom-fuse-block/orhttp://www.droppinhzcaraudio.com/toolmaker-single-4-0-dual-fuse-holder/ 1992 Honda Civic CX Hatchback K24a2 Swap
