Grounding to tire well
The vm-1 is a pretty accurate tool so I would stick with those numbers. Even if you wired it directly to the amp you might see the 14v that the dmm reads which only gains a couple tenths of 1v. Long story short, you are still going to need a bigger alt ASAP to hold voltage to at least the pcm specs.
  • Who's Online   0 Members, 0 Anonymous, 831 Guests (See full list)
