g2shuck Posted October 15, 2015 Author Report Posted October 15, 2015 Ok so withour time alignment am I better off to try to keep them close to the mid in the door panel or am I not understanding rhat correctly? 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
White Lightning Posted October 15, 2015 Report Posted October 15, 2015 I'm saying you have to test and tune. Test in multiple locations and see what works and what doesn't. No one can tell you exactly where to place your tweeters and work perfect. I'm just trying to help with the limitations of the component set theory ... and this challenge may be more difficult running at 2 ohms ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
g2shuck Posted October 15, 2015 Author Report Posted October 15, 2015 Ok test and tune it is then. Thank you for all the help and explanation. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
White Lightning Posted October 16, 2015 Report Posted October 16, 2015 Use a tape measure to get the distance from the passenger midbass driver to the listener's right ear. The distance to the tweeter should be exactly the same. The angles can be different but the measuring distance should be the same. This way, you should only need 2 channels of time alignment instead of 4. Calculate the difference from the left side and offset until you have a great center point when the singer sounds prominent on the center on top of the hood of the vehicle. That should be enought to get you bit bu the SQ bug ... LOL Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
