Kris4b11 Posted October 18, 2015 Report Posted October 18, 2015 For a while I had my eyes on B2 Audio and just loved the way their products looked. My new car is white so that just grabbed my attention even more. Right now im debating on going with 2 IS10's or 1 HN12, Does this box look ok for the 2 10s? I wanted to do a 6" octoport. Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
Shenker Posted October 22, 2015 Report Posted October 22, 2015 Youre going to want to bring up that port area/ft to around 14 if you can. And you might want to bring that tuning up just a little bit, thats pretty low for a sub that has a rated Fs of 38, maybe bring it closer to around 36 if you can, changing port area might do that for you though. and also If im not mistaken I think octoports require different calculations? I dont know if they work the same as using a round port, Then again I could be mistaken on that. Other than that looks good! -If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome. -"No way he's OCD." -said none of the people that know me ever. 04' Suburban "Lucifer" A.K.A #Lucii (Under Construction) 4 10s on 4kW in 6cu net @~28hz /////Alpine Crescendo KnuKoncepts Optima SHCA Build Thread 92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~ Gutted pipes 96,000 OG KM's (59,000 mi) -System Removed- 1 10 on 1kW 89' Gen 3 Honda Prelude SI AWS "Odis" Bone Stock Possibly going to stance it
CleanSierra Posted October 22, 2015 Report Posted October 22, 2015 Port area per foot doesn't mean dick. Total port area is what you're after. For single 12 or 2 of those 10s, that should be plenty of port. Round ports are different than octoports also, as mentioned. I've built a few octoport boxes and there is a good calculator for area here: http://rechneronline.de/pi/octagon.php That formula will give you cuts and angles as well, which is 22.5°. As far as tuning preference goes, it's just that, preference. Just for a piece of mind, I measured the HN10 with my IM-SG and found the Fs to be different. It was closer to 34Hz. Im not the one you want to try to troll. Just a fyi for you.
