vw0404 Posted October 20, 2015 Author Report Posted October 20, 2015 ill try taking them out...like no air and its not loud at all
_paralyzed_ Posted October 20, 2015 Report Posted October 20, 2015 That sounds like they are out of phase. Hopefully you didn't already damage the subs.Even the shittiest box and shittiest 18" woofers would make a lot of noise.
vw0404 Posted October 20, 2015 Author Report Posted October 20, 2015 can someone give me a quick 101 on phase please
vw0404 Posted October 20, 2015 Author Report Posted October 20, 2015 or what causes it ? i understand there playing at slightly different time
firebirdude Posted October 20, 2015 Report Posted October 20, 2015 You have the positive and negative reversed on ONE sub. Follow the speaker wire from each sub and to your amp. Maybe you have it crossed at your amp or at the subwoofer.
firebirdude Posted October 20, 2015 Report Posted October 20, 2015 You've got dual 1 ohm coils? Wired in series for 2 ohm on each BC3500? Or in parallel for 1/2 ohm on each BC3500?
vw0404 Posted October 20, 2015 Author Report Posted October 20, 2015 parallel. I thought that made it 1ohm final load? im strapping the amps which brings it down to half ohm if im correct ?
Triticum Agricolam Posted October 20, 2015 Report Posted October 20, 2015 can someone give me a quick 101 on phase please Out of phase just means having your positive and negative wires reversed some where. One way to test for it is to do what called the pop test. Unhook the speaker wires where they go into the amp and touch them briefly to a 9 volt battery. With the positive wire going to the positive terminal on the battery the cone should move out. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
_paralyzed_ Posted October 20, 2015 Report Posted October 20, 2015 Like was said, negative and positive are reversed on one sub.Being out of phase makes one sub push, while the other one pulls. This cancels out the sound from one another. But now that we are thinking about phase I wonder if one of your subs has the two voice coils out of phase.Basically check the wiring. Make sure all positives go to positive and all negatives go to negative.
