ron Posted October 23, 2015 Report Posted October 23, 2015 Two dc audio 2ks on 2 dc audio 15inch m2xls 39X29x17 Port? Subwoofers up port back or subwoofers and port back 15.5H x 6.5w x 30? 15.5H x ???
MotorCityFats13 Posted October 23, 2015 Report Posted October 23, 2015 using your max dimensions its pretty hard for me to make a box with the required volumes and port area.... this layout would be subs up port back... 140in of port @ 36hz tune.... you would still need to add some bracing
CleanSierra Posted October 23, 2015 Report Posted October 23, 2015 What kind of music do you listen to Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted October 23, 2015 Report Posted October 23, 2015 What dimension is your height here? Im not the one you want to try to troll. Just a fyi for you.
ron Posted October 23, 2015 Author Report Posted October 23, 2015 I listen to just about everything but mostly rap. metal,classic rock,country,r&b,rap
ron Posted October 23, 2015 Author Report Posted October 23, 2015 I think i might of screwed up i already cut 3/4 inch mdf to 39 wide 17 tall and 29 deep
ron Posted October 23, 2015 Author Report Posted October 23, 2015 I was trying subs up port back i have a explorer
CleanSierra Posted October 23, 2015 Report Posted October 23, 2015 You're fine, I've got something for you Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted October 23, 2015 Report Posted October 23, 2015 Sides: 25.5X14.75(2 pieces) Back : 39.0X14.75(1 piece) Front: 16.25X14.75(2 pieces) Port: 19.25X14.75(2 pieces) Top: 39X17(2 pieces) for double baffle Bottom: 39X17(1 piece) Tune is 35 Hz, internal volume is a bit over 6.5 cubes net airspace. Port area ~96" Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted October 23, 2015 Report Posted October 23, 2015 Subs will go on top. The reason I left the port height at 14.75" is to account for the double baffle. Any questions, let me know. Im not the one you want to try to troll. Just a fyi for you.
