LED resistance help appreciated
I'm trying to wire a string of led's as such:
12v - x-x-x-x-x-x-x-x-x-x-x-x - resistor - ground
But I don't know how to calculate what resistor to use, the forward voltage od each led is 3.6 with 60Ma forward current,if someone could provide me the info I'd greatly appreciate it. I've found online calcs but they show how to wire 4 sets of 3 leds, I'm seeking to put all in a row, if possible.
The way you're wiring it now is such that if any one burns out, the whole string will go out. It will be like a dollar store set of Christmas lights.
V = IR should help you calculate the resistance pretty easily.
Run the LEDs in parallel, so each is connected to a common 12V bus. Forward voltage on the LEDs is 3.6V, so 12V-3.6Vdrop across the circuit is 8.4V. Currents sum up in parallel, so 12x0.06A = 0.72A. Finally, plug in to V = IR. So 8.4V/0.72A = 11.6666ohm. Look for a 12ohm resistor rated for 1A or so of current and let er rip.
Also if you really want to run 12 3.6V LEDs in series you're gonna need a lot more than a 12V source.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
