Amplifer volume control
Allen Lancos
In reference to the remote bass control/knob - is there a way to reduce bass output down to 0 without adjusting anything on the head unit itself? Reason i ask is there are some songs i listen too where the balance between music and bass are rediculous. I can have the bass knob turned all the way down and still cant hear the audio side of the music! I would love some kind of remote control feature with full adjustability "from no bass to full bass" if its even possible... I am currently having to manually go into my audio settings in the head unit to adjust bass levels, the standard remote bass knob i have (+/- 18db) isnt enough adjustment! Thanks in advance for any help!
Current amp is a Rockford P1000
Sone to be installed amp is an NS1 once i finish buying everything! Tired of seeing this amp just sit here!
I'll do body filler all day every day, but this reinforced, fortified fucking kitty hair can kiss my balls.
First you turn the knob to 100%, then you properly set your amp gain. After that, when ever you turn down the knob you're actually lowering the input voltage going to the amp.
The knob your currently using only adjusts the bass boost of your amp, it doesn't actually lower the signal at all
you want a lc-1. will give u zero bass to max bass. dont think it would matter as long as it is in between hu and amp. just need longer rcas.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
hu rca to lc1 in. lc1 out to rca to amp done.
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
