Noser's 91 Ranger slow build
Heres the amps mounted on a piece of wood. Not wired yet i just wanted to put it together. Sub stage will happen later i want to change from a bench to 2 single seats. For now i wanna kill the highs ????
Yea you are right i want to paint them black? Im not sure yet still deciding whether to paint all the panels black or just clean up the grey ones to look new. Im leaning towards the black tho. Thank you for your input ???
Quick question guys about midbass. I might pick up a jl audio 500/5 and plan on running it ass a midbass amp. But im not sure what speakers to run. I was wondering about just 2 10's one in each door. Or 2 8" in each door.
Help?
Quick question guys.
The 450/4 is a staggered power supply the fronts put 150 to each channel i believe, the rear channels are 75 each channel, but it says i can bridge 3-4 channel to put 300 watts to both problem is it only 3 ohm stable. I cant wire it doen but i can wire up,will this affect sound quality?
  • 1 month later...
I just did the 2 seat converstion on it. I hit up a junkyard when it was half off and baught the 60/40 seat bracket. I already havr an 95 explorer here so i took the seats, planning on adapting the center console next.
  • 3 months later...
Just came up on 50' of 2/0 gauge cable for $70 guys. Deal deal deal.
Now my question, i want to run 3 runs, 2 positive and 1 negative. The guy i bought the cable from told me i dont need to run grounds. I can use the frame.
Also to wire my 3 batteries iread to grab the positive fr9m one end and the negative from the last battery
ANY HELP IS APPRICIATED
Save your neg run and ground to frame. Do the big 3 under the hood. Grind all metal bare for grounds. Enjoy....
Clean, sounds pretty simple
Where do i use fuses? I was th8nking on thr big 3, on each battery and before the amp.
For the amp i want to run dual or triple inputs, since you say i can use my frame as the ground i can save on cable
Just about done i think. Just came up on 50' of 2/0 gauge just need to cut to lenght, terminate and wire up my second alt. Planning on running it at .5
Ima stuff em in my passenger seat this weekend hopefully til i hqve the funds for a blow through. Just buying the accordian boot a lid cover and some wood to make lil tunnel for the subs to shoot difrectly into the cabin.
  • Who's Online   0 Members, 0 Anonymous, 1422 Guests (See full list)
