erf561 Posted October 29, 2015 Report Posted October 29, 2015 Hello,I have a 2014 Scion Tc that I want to do a ported enclosure the specs I have to work with are 38"W 16"H 19"D, I've tried messing around in the torres calculator but cant seem to get proper tuning at the port. I know a lot of you are very experienced so if you could give me some advice I'd really appreciate it, and also let me know if its possible in the first place or just go with 3f t ³ sealed enclosure like sundown has recommended? Thank you very much and if it helps listen to elec/rap/hip hop,
erf561 Posted October 30, 2015 Author Report Posted October 30, 2015 Anyone available to help with input in this enclosure design? It would really help me out thanks alot!
Triticum Agricolam Posted October 30, 2015 Report Posted October 30, 2015 What amp are you running? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
erf561 Posted October 30, 2015 Author Report Posted October 30, 2015 Rockford 1200x1 at 1ohm for the time being sure ill need something bigger down the road
Joe X Posted October 30, 2015 Report Posted October 30, 2015 With the 19" depth how much clearance do you have to the rear gate?
erf561 Posted October 31, 2015 Author Report Posted October 31, 2015 I think I miss understood you, I thought you meant height between enclosure and deck lid, there is about 10" from desired enclosure area and rear trunk gate but the height drops due to the trim in the trunk.
Joe X Posted October 31, 2015 Report Posted October 31, 2015 Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 4 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
erf561 Posted October 31, 2015 Author Report Posted October 31, 2015 Is there any way to shave an inch off of height or depth to clear the paneling on the hatch? Thanks so much for the help so far I've seen you in just about every thread helping out.
