rhcpepper7 Posted October 29, 2015 Report Posted October 29, 2015 Whats the smallest box i could make 2 ported E10s to? I would want it tuned to 32hz. max depth i can go is 21 inches....if the ports were under the 2 subs could i save room on the width? I want the width to be as short as possible and height can be whatever to accommodate. they have a recommended. ported box size of 1 cubic foot each with a displacement of .11 cubic feet each. I would prefer box to have subs facing forward with the port under subs to save on width. I really dont want width to be more then 26-28 inches. If someone could help with box design it would be greatly appreciated.
rhcpepper7 Posted October 29, 2015 Author Report Posted October 29, 2015 Jeep patriot. I want to try to keep a little space in the back,so im id like width to be on the shorter wide if possible.
Joe X Posted October 29, 2015 Report Posted October 29, 2015 So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/2", figure is just an assembly guide:
rhcpepper7 Posted October 30, 2015 Author Report Posted October 30, 2015 Oo I like that alot. I have a question though, why would you recommens 35hz over 32hz for tuning?
Joe X Posted October 31, 2015 Report Posted October 31, 2015 A larger box will result if tuning is lowered, anyways higher tuning makes you louder in that bigger vehicle so unless you listen to really low tuned stuff you may do better with a little higher tuning, your choice, let me know.
rhcpepper7 Posted October 31, 2015 Author Report Posted October 31, 2015 Yes i would like a tuning of 33 hz. Would you be able to keep the width at 24 inch and depth at 20-21 but increase the height of the box to achieve the 32 hz and the little more volume needed? I dont care what the height of the box is, thanks. Also would i acually be able to place the subs forward rather then firing up in the air? (just so i would be able to store stuff on top of the subwoofer box) I really appreciate the help! Edit my amp does not have a subsonic filter. It is a JL JX 1000.1D is that ok? Have you heard anything about this amp? i haven't used it yet.
Joe X Posted October 31, 2015 Report Posted October 31, 2015 So here is a new plan, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/2", figure is just an assembly guide:
rhcpepper7 Posted November 1, 2015 Author Report Posted November 1, 2015 You're the man! Thanks for the design, i will build the box whenever time permits and buy the subs to go with it : ) I'll try to post a video of the results! Thanks!
Joe X Posted November 2, 2015 Report Posted November 2, 2015 Ok, you're welcome, the amp is alright if you were to need subsonic filter get 30Hz Fmod passives; http://www.ebay.com/itm/FMOD-Crossover-Pair-30-Hz-High-Pass-266-248-/321558128707?hash=item4ade5ba843:g:facAAOSwDN1URV7Q
