Larry BigCountry Posted October 31, 2015 Report Posted October 31, 2015 I know you are supposed to wire the 6 supercaps together in series for the bank, but how do you wire the 2 banks together? Do you connect the banks together in parallel or series? Thank you.
islandpride684 Posted October 31, 2015 Report Posted October 31, 2015 if 1 bank equals 12v then 2 banks wired in parallel equals 12v, but if 1 bank equals 6v then 2 banks wired in series equals 12v......make sense? \ Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
3vil Posted October 31, 2015 Report Posted October 31, 2015 ^^^ this^^^ Wiring in series stacks voltage (think about D-cell batteries in a Maglite) Wiring in parallel stacks amperage (like how you add extra batts to your car)
AA98hoe Posted November 1, 2015 Report Posted November 1, 2015 U parrellel the banks either with a buss bar or wire then go from batt to caps to amp TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
