2008 trailblazer LS 4 channel wiring help
i was going to go hook up my 4 channel amp with all new speaker wire today and i can do my back doors because its the rubber tube that im used to running wires through, but the front doors have a plug type deal that ive never had to deal with, how do i run new speaker wire through my front doors? cleanly
Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm
Door Speakers - RE REX 5x7/6x9
Battery - Kinetik HC 2000
Sub Amp - Crescendo BC2000
Door Amp - Alpine MRP-F300
Head Unit - Pioneer DEH-X8600BS
Disconnect that plug from the body/door. Look inside the plug for open or unused wiring connections. Drill a small hole through both sides of the plug, large enough for your wire to fit through. Feed the wire through the body, then the car side of the plug, then the door side of the plug, then into the door to where ever your speakers are. Slowly put the plug back together while gently pulling the slack out of the speaker wire, so that the wire doesn't get pinched or bend any of the pins on the plug. Repeat that all for the other door.
when im drilling the hole am i drilling it the size of the stripped wire or the coated wire?
Let's say you had plug like the pic below, you could drill a hole through the unused pin location just to the right of the guys thumb. Then feed the wire (with it's jacket still on!) through that hole and into your door.
You have to do this to both sides of the plug, the door side and the body side. It must be the same pin locations so that the wire has a straight path to follow once the plug is all reconnected.
  • 2 months later...
Is this truck equipped with the Bose system or no?
Build in progress:
Kenwood DNX890HD
Rockford Fosgate White wolf RCA's
2 Rockford Fosgate T400.4 on RF fanatic q components (6.5 in the kick, 6.5 in the front doors, 5.25 in rear doors)
2 Rockford Fosgate T2500's on sub
1 Fi car audio Team 15 D1
XS Power D3400 and three D975's in the rear
Mechman Elite 370
Stinger power connections and cable
