mayday187 Posted November 5, 2015 Report Posted November 5, 2015 I have a box design from Joe X that i want to rebuild to use with the Xtrpro152d subs. [/url]">http:// picture of box design. width and depth dimensions are still good, but would like to bring height down about 3 inches. Played around with Torres box calculator and came up with these parameters. Just would like to bring the box tune down to around 34 hz. [/url]">http:// so also need to know port length if these modifications to the box would work. Also here are the T/S parameters for the subs. The 152d are in the middle column [/url]">http://http://s288.photobucket.com/user/tahoe201/media/speaker%20specs/orion%20xtrpro152d_zpswwagdhw3.jpg.html'>. Can't really order the sub until i know i can get this done so any and all help is greatly appreciated.
Joe X Posted November 5, 2015 Report Posted November 5, 2015 You don't need to do the box 3 net per driver just because it says on the manual, actually many Orion subs are used in larger than the manufacturer recommended, in any case tuning lower will require to make your port longer. But again those subs should work fine in 3.5 net unless you will be overpowering heavily.
mayday187 Posted November 6, 2015 Author Report Posted November 6, 2015 actually will be running 10k to the subs. and want to keep the profile low to retain use of cargo cover. And about vent length is Torres fairly accurate? used Subwoofer design toolbox, winisd and Torres box designer and always get different port lengths for a specific tuned frequency. [/url]">http://http://s288.photobucket.com/user/tahoe201/media/speaker%20specs/Screenshot%202015-11-06%2002.17.32_zpsol77k3mj.png.html'> adjusted a few things.box height and port length.If i'm overpowering the subs what happens then?
Joe X Posted November 6, 2015 Report Posted November 6, 2015 Torres accuracy is usable most of the times but then it fails unexpectedly in some cases like it happened a few threads below, that fail among other leaves me thinking if I should keep recommending it, anyways, at least WinISD is not designed for slot ports so you are not supposed to get same results as Torres because of that and also because Torres miscalculates port displacement, 1-2 Hz error should be no problem though, if you have the driver entered in WinISD you can estimate driver excursion, try to maintain excursion below Xmax at all frequencies for the intended power and box specs, getting above Xmax may result in distortion and pushing further will cause bottoming out.
mayday187 Posted November 10, 2015 Author Report Posted November 10, 2015 Ok. so i loaded Winisd with speaker parameters to check the xmax, and the results were higher than manufactuers specs. what can i do to remedy this. [/url]">http://http://s288.photobucket.com/user/tahoe201/media/speaker%20specs/Screenshot%202015-11-09%2009.49.30_zps2qoog5ui.png.html'>
Triticum Agricolam Posted November 10, 2015 Report Posted November 10, 2015 With most subs you can exceed Xmax by a small amount without breaking anything, distortion will just go up. If you want to decrease excursion though you can decrease the amount of power you are putting to the sub, or decrease the net volume of the enclosure. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
mayday187 Posted November 10, 2015 Author Report Posted November 10, 2015 Which would you do? gain down the amp or make box smaller. If making the box smaller what size would you suggest and what port length for tuning.
mayday187 Posted November 10, 2015 Author Report Posted November 10, 2015 Made box a little smaller and brought the tune frequency up. how does this look. [/url]">http:// [/url]">http://http://s288.photobucket.com/user/tahoe201/media/speaker%20specs/Screenshot%202015-11-10%2002.16.58_zpsfzjnxdlv.png.html'> any and all suggestions are welcome.
