mike-g Posted November 6, 2015 Report Posted November 6, 2015 I'm making a tline for 1 eclipse 12 and need help with the design. I ve got 9.5 from surround. Which gives me 70-71sqin.the mounting depth is 8 1\4 Cut out is 11,how do I make a line equal to SD but fit the subs depth?please and thanks for help
mike-g Posted November 7, 2015 Author Report Posted November 7, 2015 Length is 124" how do make the line 12-13" by whatever to fit the depth?can I make it bigger to fit the sub but tapper it to SD of 70-72" sq.will that effect it?
Triticum Agricolam Posted November 7, 2015 Report Posted November 7, 2015 You can reverse mount the sub, if the space allows. Your line is 124" long? What are you trying to tune it to? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
mike-g Posted November 7, 2015 Author Report Posted November 7, 2015 27hz the sub's fs what would your rec.be.is revs mount worse,the same for output
mike-g Posted November 7, 2015 Author Report Posted November 7, 2015 Will it still have the same effect reverse mount.
LT.Smoke Posted November 7, 2015 Report Posted November 7, 2015 Honestly I would tune a bit higher because the roll off is steep in T-lines. I had a Tline tuned to 34hz with my mtx5500 12 which got swapped to a Mmats Dreadnaut later on and it did great on 1500 watts Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
Triticum Agricolam Posted November 7, 2015 Report Posted November 7, 2015 So what model of Eclipse sub are you using? Why do you want to use a T-line anyway? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
mike-g Posted November 7, 2015 Author Report Posted November 7, 2015 Sw9122 and I've read the pinned tutorial a few times and the specs I find on the web about the sub seem excellent for a t line I ve only got one and was thinking it would be a good choice for loud,low bass?could be totally wrong,I don't know every one in the tline tutorial say it great
mike-g Posted November 7, 2015 Author Report Posted November 7, 2015 What would your opinion be on loud box for one?I'm just curious if I can make the 1 12 louder than my current 2 12" pioneer 3003d4 in a 3cuft net @35hz.just basically trying something
LT.Smoke Posted November 7, 2015 Report Posted November 7, 2015 Sw9122 and I've read the pinned tutorial a few times and the specs I find on the web about the sub seem excellent for a t line I ve only got one and was thinking it would be a good choice for loud,low bass?could be totally wrong,I don't know every one in the tline tutorial say it great T-lines are killer on low power. Ive had 4 diff tlines in 2 diff trunk cars the output is phenomenal the response is killer the biggest thing I would say is do not play too far below your tuning because there's like almost zero back pressure initi line so there's nothing to stop the sub from over excursion so if you abuse your sub you can fry it very easily but if you play respectably and smart will be just fine I've had for setups in two different cars if you need any extra advice feel free to PM me Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
