? about a tline enlosure
mike-g
I'm making a tline for 1 eclipse 12 and need help with the design. I ve got 9.5 from surround. Which gives me 70-71sqin.the mounting depth is 8 1\4 Cut out is 11,how do I make a line equal to SD but fit the subs depth?please and thanks for help
You can reverse mount the sub, if the space allows.
Your line is 124" long? What are you trying to tune it to?
Builds:
Honestly I would tune a bit higher because the roll off is steep in T-lines. I had a Tline tuned to 34hz with my mtx5500 12 which got swapped to a Mmats Dreadnaut later on and it did great on 1500 watts
Team MaxRetribution
Si Vis Pacem Parabellum
So what model of Eclipse sub are you using? Why do you want to use a T-line anyway?
Builds:
Sw9122 and I've read the pinned tutorial a few times and the specs I find on the web about the sub seem excellent for a t line I ve only got one and was thinking it would be a good choice for loud,low bass?could be totally wrong,I don't know every one in the tline tutorial say it great
What would your opinion be on loud box for one?I'm just curious if I can make the 1 12 louder than my current 2 12" pioneer 3003d4 in a 3cuft net @35hz.just basically trying something
T-lines are killer on low power. Ive had 4 diff tlines in 2 diff trunk cars the output is phenomenal the response is killer the biggest thing I would say is do not play too far below your tuning because there's like almost zero back pressure initi line so there's nothing to stop the sub from over excursion so if you abuse your sub you can fry it very easily but if you play respectably and smart will be just fine I've had for setups in two different cars if you need any extra advice feel free to PM me
Team MaxRetribution
  • Who's Online   1 Member, 0 Anonymous, 1066 Guests (See full list)
