Triticum Agricolam Posted November 12, 2015 Report Posted November 12, 2015 Now I wonder how it would sound in the two Cube net Tinned to 33 Lol, only one what to find out. The output from the t-line is probably pretty peaky down low, which would explain why the higher frequencies don't sound as good. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
mike-g Posted November 12, 2015 Author Report Posted November 12, 2015 Yes its pretty peaky down low could me changeing the line 104sq for the first 25" or so cause that,or would it have been that way because of the sub
LT.Smoke Posted November 12, 2015 Report Posted November 12, 2015 T-lines play great down to about an octave below and an octave above tuning... Example... My T-line was tuned to 39.76 with my 8... It would play great from about 25-65... I had the mids take over at 65 etc Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
Triticum Agricolam Posted November 12, 2015 Report Posted November 12, 2015 Yes its pretty peaky down low could me changeing the line 104sq for the first 25" or so cause that,or would it have been that way because of the sub The peakyness is caused by the overall specs of the line (cross sectional area, taper, etc), making the first 25" larger may have contributed to it slightly, but it was probably not the main cause of it. You may have benefited from a little bit higher tuning frequency as well. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
mike-g Posted November 12, 2015 Author Report Posted November 12, 2015 Yeah I have no mid bass at all,it sounds good about like you said,20-40's sound good I'm tuned to 30 I believe I should've inverted and made the line closer to 70sq 109"Long Its like 30 sq bigger for about 1/4 of the line I'm curious if that affected the performance? I don't think it was to bad for my third enclosure build
mike-g Posted November 12, 2015 Author Report Posted November 12, 2015 I just read your response,after I responded last,that's cool it was a good experience thanks for all the help every one.
LT.Smoke Posted November 12, 2015 Report Posted November 12, 2015 I just read your response,after I responded last,that's cool it was a good experience thanks for all the help every one. Hit up my friend that I gave you the number... Like I said he is the guy that built my T-lines and they sounded Killer... maybe you did something incorrectly?? Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
Triticum Agricolam Posted November 12, 2015 Report Posted November 12, 2015 I just read your response,after I responded last,that's cool it was a good experience thanks for all the help every one. If you want to give T-lines another try, post your max dimensions and I might be able to come up with something for you. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
