So the first question is, does deadening the floor help out a lot, like would it make an audioable difference? The second question is, will 2 d3400's with a stock z71 Tahoe alt be enough to support a SCV-2000? Thanks in advance.
Deadening the floor can help remove unwanted noise and vibrations from driving on the road, engine noise, and from your music and other noise sources. But it's going to take more than just butyl deadener to do it right.
And that electrical setup will work just fine. No need for a HO alt unless you're going to add another 1000+ watts of amp power
Alright I hear ya. Thank you sir
