Help on a 4th order blow throu box
Haterhurter
Are you sure it's worth permanently disfiguring your vehicle for a single 15"?
What are your goals for the system? Do you want it to sound decent or do you just want to get as loud as possible?
Builds:
First off, when it comes to bandpass box design, ratios are dumb and are a flawed way to design. They are an oversimplification and they imply that making the rear chamber smaller has the same effect as making the front chamber larger and vice versa, which is completely untrue. When designing a bandpass box you size the rear chamber based on the amount of power you are going to be running and to get the sealed resonant frequency you desire (usually around 45 hz). The front chamber is then sized and tuned to get the frequency response you want. Keep in mind that with bandpass boxes, everything is a tradeoff. If you want a box that sounds decent, with a wide frequency range and smooth response, its going to cost you efficiency. A ported box will be more efficient. To get more efficient than a ported box, you are going to have to give up a lot of bandwidth. In the quest to get as loud as possible it's very easy to end up with a one-note-wonder.
Exactly what model of HCCA 15 are you using? There are a couple different versions. What's your amp?
Builds:
What box would be the best option for a blowthru
I think a 4th order bandpass box will work well for what you want to do. I just wanted to make sure you had some understanding of what goes into designing a bandpass box and what consequences different design decisions have.
Is this the sub you have? http://www.orioncaraudio.com/hcca-series-subwoofers-/27-hcca152-15inch-dual-2ohm.html
Builds:
