Matthew Williams Posted November 28, 2015 Report Posted November 28, 2015 Just need a box design for a 15in FI Q car tuned to 28hz. dimensions are 20h x 34L x 22W
Joe X Posted November 30, 2015 Report Posted November 30, 2015 22" depth is maximum? Also may I ask you why would you want such a low tuning?
Matthew Williams Posted November 30, 2015 Author Report Posted November 30, 2015 22" depth is maximum? Also may I ask you why would you want such a low tuning? Because the I listen to a lot of decaf and a lot of chopped and screwed. Also the website suggests that type of tuning for that box anyway.
Shenker Posted November 30, 2015 Report Posted November 30, 2015 coming from someone that's tuned at 28hz, and listens to a lot of decaf, slowed, etc music, tune around 32-35 if you can, I have a lot of drop off starting mid 30hz range and although I dont mind it enough to redesign a setup (due to space restrictions for the box I HAD to tune low for proper space for the subs), I wish in hind sight that I could have tuned around 33hz or 34hz after displacement to pick up some of those higher notes. -If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome. -"No way he's OCD." -said none of the people that know me ever. 04' Suburban "Lucifer" A.K.A #Lucii (Under Construction) 4 10s on 4kW in 6cu net @~28hz /////Alpine Crescendo KnuKoncepts Optima SHCA Build Thread 92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~ Gutted pipes 96,000 OG KM's (59,000 mi) -System Removed- 1 10 on 1kW 89' Gen 3 Honda Prelude SI AWS "Odis" Bone Stock Possibly going to stance it
Matthew Williams Posted December 1, 2015 Author Report Posted December 1, 2015 I will take whatever suggestions I can get. I would go between 30 - 33hz. I
Joe X Posted December 1, 2015 Report Posted December 1, 2015 So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Matthew Williams Posted December 2, 2015 Author Report Posted December 2, 2015 Would this clearance work well with my hatchback? Just wondering since I usually had the port facing up. If not, I of course will use this
Joe X Posted December 2, 2015 Report Posted December 2, 2015 There should be 4" clearance if you measured correctly (from the top of the back seat or at 20h), if not it can easily be done port up as well.
Matthew Williams Posted December 2, 2015 Author Report Posted December 2, 2015 There should be 4" clearance if you measured correctly (from the top of the back seat or at 20h), if not it can easily be done port up as well. Thanks Joe I appreciate the help man. I really mean it.
