Mitchaford Posted December 4, 2015 Report Posted December 4, 2015 Searched the forum and surprisingly didn't find a box design for this sub. Box size thread: http://www.stevemeadedesigns.com/board/topic/187809-hdc3-hdc4-optimum-enclosure-size/?hl=+hdc3 " HDC312 - 2.25 cube net with 16 sq inch port area per cube - tune between 34-39 hz " Dimensions: Height: 18 Depth: 40 Length: 30 Tuning: 34 This is going in a VW Jetta 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
Joe X Posted December 4, 2015 Report Posted December 4, 2015 So here is a suggestion for a trunk car, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Mitchaford Posted December 4, 2015 Author Report Posted December 4, 2015 So here is a suggestion for a trunk car, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Absolutely beautiful thank you so much. My last setup had the sub facing out towards the trunk. Would you suggest placement facing in the trunk? With the appropriate port clearance. 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
Joe X Posted December 4, 2015 Report Posted December 4, 2015 Everything firing back or front firing sealed off (if you want to bother and seats fold down).
Mitchaford Posted December 4, 2015 Author Report Posted December 4, 2015 Everything firing back or front firing sealed off (if you want to bother and seats fold down). Ill just play around with the box placement and see what happens. Thank you again! 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
