Has anybody ever been let down by the Minimum Port Area???
jfoodstamp
So is it your guys opinion that if I keep my vent area around 200 square inches I wont suffer any adverse affects?
Keep the area ratio of your port low, meaning a not too thin port.
Ok Joe you may have to dumb this down for me. My width of port is 10 inches by 19.5 tall. This is a slot port using one 3/4 inch board as the port. I have considered doubling that if necessary. What ratio are we talking about?
So I got it then- lol. In your opinion should I double my port board thickness to 1.5?
Your can double layer your baffle, yes. If you post your box layout you may get some additional tips.
2007 Ford Focus zx3 hatchback
Box will be 36 wide x 22 high x 40 deep.
Double Baffled top
Woofers will be all the way to the rear of the hatch firing up
Port will be firing to the driver side in front of woofers.
Port wall will double as bracing. 45 degree corners
Tuning will be 33 or 34hz based in tweaking port still
Woofers Sundown Sa18
Amp Ct sounds 2200.1 at 2 ohms until I can swing more electrical then will be ran at .5 ohm
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
