You can do a 4 way with the 80pea. Just depends on how you look at it.
80 pea with it's filter for low mid set at around 63GA. Use a splitter for the rca pre out to the mid bad/mid range app. For the channel running the mid bass set the filter to low pass and tune it some where around 200hz. For the mid range channel set the filter to HP and adjust it to around 200hz.
On the deck set the midhigh filter to around 3-4khz.
Now by using the billy in fillets on the app and the www you have effectively set up a mid bad and mid range speaker.
Of course you still have to set up the subs and tweets along with fine tuning the mid bass and mid range but it works
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
12511145_1144374358907019_1898031465_o_z
12476739_1144374378907017_1661742998_o_z
138.6 @47hz sealed on the dash with 418 watts clamped. 132.3 @30hz and 136.3@40hz. Very nice response and does really well on music. Not too bad for a pair of 8's on less than 500 watts.
  • Who's Online   0 Members, 0 Anonymous, 1145 Guests (See full list)
