2 12 in 300W rms/ 1000W peak audiopipe subs enclosure help
Wolfbane
I'm new to car audio and this is my first audio system. I just got in my amp and 2 12 in audiopipe subs. i only wanted something that added a decent amount of thump to my music so dont judge to harshly. I dont have a lot of space in my ford fiesta sedan so can someone help me out.
edge to edge: 12-3/16 in
mounting depth is 5 - 5/8 in.
fb=34 Hz
Vb= 1.75 ft^3 per sub
the space i have to work with is:
height: 20 in
Width: 35 in
depth: 20 in
Trying to keep a decent amount of usable space due to gf.
If there is any other info you need let me know.
which woofers and amp specifically? And give us your max dimensions or the dimensions you'd like to be within and someone much more knowledgeable than myself should be able to help out.
        This is my signature, there are many like it but this one is mine.
the woofers are ts-pp2-12 audiopipe subs
the amp is apcl-2002 1000W audiopipe
absolute and i mean absolute dimensions are
height: 20 in
width: behind seats: 35 in
by opening in trunk: 49 in
depth: total: 40 in or so
the previous dimensions that i posted are what im trying to stay in between if possible.
Dia = 12
Sensitivity (2.83V @ 1 m) = 86 dB
Power handling= 300 W rms / 1000 watt peak
Frequency response = 29 to 1500 Hz
Nominal impedance = 4 ohms
Voice coil diameter = 2"
Revc ( ohms) = 3.6
Levc (mH) = 2.0
Sd (in) = 35
Sd (m) = 530
Bl = 16
Vas (ft) = 1.5
Vas (liters) = 43
Cms (um/N) = 108
Mms (grams) = 220
Mmd (grams) = 213
Fs (Hz) = 32
Qms = 2.7
Qes = 0.63
Qts = 0.51
Hag (in) = 0.310
Hag (mm) = 8
Hvc (in) = 1.26
Hvc (mm) = 32
Xmax (in) = 0.48
Xmax (mm) = 12.1
Sealed box volume = 1.00ft^3 per sub
Ported box volume = 1.75 ft^3 per sub
Dimensions :
Edge to edge: 12-3/16"
Mounting height: 5-5/8"
Cut out dia: 11-1/8"
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
