Fi n2 12's 4th order huuuge
noser7
N212
DUAL 1 | DUAL 2
Fs: 39.6 Hz | 39.2 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 6.40 | 6.47
Qes: .25 | .25
Qts: .24 | .24
Mms: 225g | 231g
Sd: 480cm^2 | 480cm^2
Vas: 23.1 l | 23.1 l
Spl: 89.5dB1W/1m | 89.4dB1W/1m
Bl: 17.8 N/A | 25.1 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 1.7-2.5cuft | 1.7-2.5cuft
Sub OD: 12.500” | 12.500”
Cut ID: 11.125” | 11.125”
Mounting depth: 0.000” | 0.000”
Displacement: 0.12cuft | 0.12cuft
You may be able to do a 6th order bandpass. I wouldn't use those N2s in a 4th order.
Builds:
Suggestions on 6th order bandpass enclosures compares to farting in the wind. It's just out there in the air.
In all seriousness, it's REALLY build specific. The vehicle will have a lot to say about it.
As others stated, those subs are not really suited for a 4th bandpass enclosure. Any guess we give you on a tuning frequency for front and rear chamber will be just that, a guess.
I'd use round PVC or aero ports to easily change tuning frequencies on either chamber until you find something that works. You will likely have to tweak the volumes of each chamber until you find a sweet spot. 6th orders are usually a lot of tuning, testing, tweaking, and if need be, rebuilding.
Best of luck man, it can be rewarding once you get it nailed.
I'm pretty sure the Tantric HDD works fine in 4th order bandpass. I was considering that sub at one point for my blowthrough. Are they still around though for support? I'd be cautious of running that brand.
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
