Unique Alternatives Posted April 17, 2008 Report Share Posted April 17, 2008 (edited) Why doesnt everyone use 6 volt batteries (2 or more) instead of 12 volt? When they have more reserve. Edited April 17, 2008 by Unique Alternatives Quote Link to comment Share on other sites More sharing options...
Aaron813 Posted April 17, 2008 Report Share Posted April 17, 2008 Because they are 6 volts not 12 Quote Link to comment Share on other sites More sharing options...
BigPimpin91 Posted April 17, 2008 Report Share Posted April 17, 2008 Weight even out between the two when you combine proper wiring configurations. 6v in Series. 12v Parallel. Maybe? Quote BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
mrrairai Posted April 17, 2008 Report Share Posted April 17, 2008 (edited) Because they are 6 volts not 12 Which has more amps tho? Because if you run 6v batts in series then you're getting 12 v but not the amperage. Edited April 17, 2008 by mrrairai Quote Member since 25 Jun 2006 2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques Link to comment Share on other sites More sharing options...
Guest Powered By Hate Posted April 17, 2008 Report Share Posted April 17, 2008 Which has more amps tho? Because if you run 6v batts in series then you're getting 12 v but not the amperage. or making giant 18v batteries outta many 6v's. Quote Link to comment Share on other sites More sharing options...
mrwigglezdj Posted April 17, 2008 Report Share Posted April 17, 2008 one reason is , if youre over 18v you wont qualify to compete, you voltage has to be 18v down...(unless theres something in the rules i missed) Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets Link to comment Share on other sites More sharing options...
Guest Powered By Hate Posted April 17, 2008 Report Share Posted April 17, 2008 one reason is , if youre over 18v you wont qualify to compete, you voltage has to be 18v down...(unless theres something in the rules i missed) If you're AT 18 is that ok? heh? 18.0? Quote Link to comment Share on other sites More sharing options...
SPL2K Posted April 17, 2008 Report Share Posted April 17, 2008 If you're AT 18 is that ok? heh? 18.0? 3 - 6 volt batts would be 18.99 volts. Quote Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA. Link to comment Share on other sites More sharing options...
Guest Powered By Hate Posted April 17, 2008 Report Share Posted April 17, 2008 3 - 6 volt batts would be 18.99 volts. So I gotta get race car batts =[ or 8v's.. Quote Link to comment Share on other sites More sharing options...
mrwigglezdj Posted April 17, 2008 Report Share Posted April 17, 2008 18.0 not 18.1 not 18.01 but 18.0volts or youre dq'd on the spot Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets Link to comment Share on other sites More sharing options...
