MADVIBES Posted December 24, 2015 Report Posted December 24, 2015 DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Snppo 95 Posted December 25, 2015 Author Report Posted December 25, 2015 Ahhhh, always been a big fan of your car. Your above build is very similar to a guy from caco named Matt that has an '02 Accord with two 12's firing forward, fully sealed with his port through the rear deck. That design seems to work very well. You can ride with your seat up and have the best of both worlds. The reason I chose not to do this setup, is because the '98-'00 Accords have a smaller area where the key latch is vs. the '01-'02, so I wouldn't have been able to have the port area I wanted. He ended up breaking his rear view mirror and sunroof. Here's his setup...
MADVIBES Posted December 25, 2015 Report Posted December 25, 2015 thats a clean set up. I bet it sounds badass. thanks for the compliments DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Snppo 95 Posted December 25, 2015 Author Report Posted December 25, 2015 thats a clean set up. I bet it sounds badass. thanks for the compliments Welcome. Unfortunately, he eventually ripped it all out, due to the weight of the subs, amps, batts, box and multi layers of deadener wreaking havoc on the frame of the car.
fecupe2001 Posted December 28, 2015 Report Posted December 28, 2015 Trunks are loud but tricky, they do get louder when sealing it off as long as the port starts where it needs to turn the cabin/box into a 6th order bandpass, i use the same principle for burp boxes or daily boxes and thank god it works, i was recently hairtricking on 2 10s and a 3K Anyways, a trunk car without sealing off gets as loud as a sealed off only by opening the trunk or the rear windows for the sound waves to get into phase. I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
tks1127 Posted December 28, 2015 Report Posted December 28, 2015 I think fully sealed, sub forward with port in between the subs would sound great for demo's and as a daily driver. I would say try a blow-through 4th or 6th order, but you're promoting your new subs, so it has to be shown. Plus, might not have enough room for a blow-through. Never seen a blow-through in a car trunk either lol! Good luck on the build.
