Matching Crossover SSF With amp Crossover and ssf
jfoodstamp
So I've got a Bad A$$ AudioControl 6xs crossover that uses chips "modules" to set selected crossover frequencies and Ive always wondered how this will work. So my AudioControl has the Subsonic filter set at 25hz. that is the cut off I want to use. So once I adjust the amp will I leave the Subsonic on the amp set to the lowest frequency if its say 10hz? does the same apply to the crossover frequencies as well?
Yeah, you only want to implement a crossover in one spot. So if you use your AudioControl box to set the SSF you should turn the filter on your amp all the way down.
Builds:
if the network is going to be doing all the cutoffs... then turn all amps to allow the most frequency .... full pass on doors.. ect and 120hz for bass and 10hz for subsonic.... make them as wide as they go
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
