forrest_siems Posted December 31, 2015 Report Posted December 31, 2015 So I just recently upgraded my amp from an audiopipe 1800 and 4ga wire to a sundown scv-2000 and sundown 0 gauge. My old audiopipe would clip around 40% gain with head unit sub level set to +5 of +15. Got everything hooked up and set gains with a multimeter (I know there are better methods) and couldn't get hardly any good output. I literally have to crank the gain to almost max and set sub to +11 of +15 on the headunit to get any decent output and then it doesn't even seem like clean power. What could be wrong? All I did was swap wiring and amp.
Vice03 Posted December 31, 2015 Report Posted December 31, 2015 What head unit is it? Some head units are completely fine to run at +15 subwoofer to get full output.
forrest_siems Posted December 31, 2015 Author Report Posted December 31, 2015 What head unit is it? Some head units are completely fine to run at +15 subwoofer to get full output. kenwoods kdc x597 excelon. 4v pre out
forrest_siems Posted December 31, 2015 Author Report Posted December 31, 2015 Another concern is having to have the gain so high for it to work
Miguels Posted December 31, 2015 Report Posted December 31, 2015 What head unit is it? Some head units are completely fine to run at +15 subwoofer to get full output. highly doubt its the head unit.. nowhere on his post does he says he replaced the HU.. maybe bad rca or installed wrong my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
forrest_siems Posted December 31, 2015 Author Report Posted December 31, 2015 What head unit is it? Some head units are completely fine to run at +15 subwoofer to get full output.highly doubt its the head unit.. nowhere on his post does he says he replaced the HU.. maybe bad rca or installed wrong I never put new rcas in. I unplugged old amp, removed old power wire, installed new power wire then plugged up the new amp. Did my rcas decide to just randomly crap out. Can they do that?
Miguels Posted December 31, 2015 Report Posted December 31, 2015 are they budget rca wires? budget wires go bad easily check all your connections my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
forrest_siems Posted December 31, 2015 Author Report Posted December 31, 2015 are they budget rca wires? budget wires go bad easily check all your connections Kicker rcas. They were $40. Ones that have that fabric braided around them if you know what I mean. I've heard certain Amps don't like certain rcas as well?
MotorCityFats13 Posted December 31, 2015 Report Posted December 31, 2015 are they budget rca wires? budget wires go bad easily check all your connections Kicker rcas. They were $40. Ones that have that fabric braided around them if you know what I mean. I've heard certain Amps don't like certain rcas as well? tony D did a full video on this subject... if you have not watched this check it out and see if its your problem
CleanSierra Posted December 31, 2015 Report Posted December 31, 2015 Take your car to a professional or have the gains set with a proper method. Im not the one you want to try to troll. Just a fyi for you.
