the instuction are wrong about half way, but since you tried it all the way up, unhook it and try again.
I will try that tell you in a minute.
I tried without it hooked up same result.
Posted (edited)
weird
Yea I don't get it either. the DD-1 works fine on 4 other brand amps and works just like advertised so there's definitely nothing wrong with the DD-1.
Edited by AzureX
I have even tried my HU in another car but with a different amp so I am pretty sure it has something to do with the NVX JAD 1200.1
Yeah, It is pretty weird. I talked to the guys at NVX about this and they knew that this was an issue. They told me to either use an O-Scope, or with a multimeter, set it at around the certified tested voltages like the ones done by Sonic Electronix, and you shouldnt have any issues. Here is a little snippet off their site:
http://i179.photobucket.com/albums/w296/MxRacer_25/Capture_zpsbt1e6sn7.jpg~original
Posted (edited)
They have no explanation to why it doesn't work though?? What do you mean set to the certified voltage??
Edited by AzureX
Posted (edited)
Not really, just the fact that there are similar issues with some other amps. That is why they can't do the "Sonic Certified" rating on all of their amps they sell. I agree though with it just being an issue with the JAD1200.1, I have 2 of them and they do the exact same thing. I have used the DD-1 on other amps without any problems. By set it to the certified voltage I mean put it on the -10db 40hz test tone and use your voltmeter and turn the gain up to the sonic certified specs, for example @ 1ohm it is certified at 1380 watts, so you would adjust your voltmeter to 36-37 volts AC. The same would apply to the 2 and 4 ohm specs.
Edited by -Stov3top-
  • Who's Online   0 Members, 0 Anonymous, 681 Guests (See full list)
