2 sundown sa 12s box help ...joex
punchy
Ok so I have a 2012 ford fusion I have 2 sundown sa 12s and need help with subwoofer box ported I got one from joex last time and be for I could make it and put in the car my wife totaled the car but now im back and ready for big bass aagain...I well have these subs fireing towards the back seat i would like to have the box tuned to 32 hz and 4 cube pleas help thank you vary much ..
my max measurements are
hight 18 inch
Width 34 inch
depth 16 inch may
So here is a suggestion, if the box takes all width and height of the trunk then do subs / port forward, sealed off, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Ok cool is that going to be batter then where the subs are on the same side and the port is all the way on the right or left ?
No, but mainly because with his design there will be a lot of port turbulence. If you aren't too concerned with port noise though it wouldn't really make much difference.
Don't trust a shop but you personally just smoked two decks, makes sense.
03' Trailblazer LT
Dayton Designer 6.5"s & Silkie tweeters
Dayton Audio Ultimax 18"
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
When firing forward the port in the middle will usually not be blocked by the car bracing as much as with the port on the side, you may want to fold down your rear seats and take a look, if you can fire everything back then there's no issue doing port on the side if you prefer that.
Not an issue if your port area is large enough and you have done the 45s inside the port.
Ya im at Taco Cabana right now with all my seats folded down and its just a big ass rectangle so a side port will definitely work
  • Who's Online   1 Member, 0 Anonymous, 518 Guests (See full list)
