Tahoe hybrid
Nope, I can't see it.
You have to use an image hosting site to post pictures here.
I will try this then
And in case that didn't work because it doesn't seem to here is this
http://prntscr.com/9ugraz
I looked on Mechman's site and don't see a self exciting alt for my Tahoe that would be bolt on. Not sure if that will be something that is easy to find or if I will need a custom mounting bracket.
I need to learn to read better. Just found the page where it says any alt can be ordered with a self exciter.
Looks like the factory bracket should work out just fine.
Just give mechman a call and they will get you hooked up with what you need.
Thanks for all the help and advice. Yeah just went out and looked under the hood I think I should be good with that solution. Looks like there is a bracket mounted currently but it only has a pulley on it. I assume that was something GM did to maintain the same length belts or something along those lines. I actually think this might make things easier because my audio stuff will be on a totally separate system from the car which to me at least seems good.
Thanks again.
No problem man.
Welcome to the forum by the way.
Anyone possibly able to post a pic of their 07-13 Chevy Tahoe Engine bay. Close up on where alternator fits. Here is what mine looks like and I am trying to figure out if I am going to need the pulley that is there now or if it is just there to hold the place of the alternator that isn't. A new bracket is 80 bucks and I don't want to buy it only to find it won't fit or work.
Thanks,
  • Who's Online   0 Members, 0 Anonymous, 948 Guests (See full list)
