From the back of my seats leaned all the way back, to the back of my hatch, is roughly 47 something inches. Now my box design is 40 inches, giving it 7 inches or less of breathing room. It is a huge 6x35 slot port in the back. I've heard different things about ports and their breathing room, just curious how I can take care of this.
7" of room is fine for a 6" X 35" port.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
That is a good ? I would also like to know how much is not enough...
2000 Chevy Blazer
ALT. - Mechman 270amp
DECK - Pioneer DEH-P4000UB
INTERIOR - Infinity Reference 6020cs
INT. AMP - RF P400-4
SUBS - 2 15" RF Punch P3s
SUB AMP - RF T1000-1bd
REAR BATT. - Stinger SPP1200
Just a lil sum sum to get me back in the game!!
How much distance should I start to worry? It might be a little bit less.
well the closer you are to the size of the port ( 6" ) the more it will start to act as an extension of the port and lower your tuning. As long as the box isnt already tuned real low it wont be a problem.
Im not sure if I'm explaining my port right. Its 35 inches in width, its 6 inches in height, and it extends 20 inches into my box (atleast, Im not sure on this yet)
yes. You are explaining it right and i understand. If your port opening is 6" tall (regardless of depth and length) and the edge of it is 6" from your tailgate or back of your car then the area between the tailgate and the back of the box becomes an extension of the port which will tune your enclosure much lower.
example....
if your port is 20" long and the box is 18" tall then you port is now actually 38" long
Guest Dylan Dude
yes and he's saying you don't want to be near the smallest dimension, which would be 6" in your case. Because then the back wall of your hatch will start to act like the port wall.
so yes you will loose output.... but gain low end extension... and what u loose isnt much
it would be the equivalent of tuning ur box lower
ie: instead of it going 20" into the box at least, the subs would (for hypothetical purposes) think the port length increased, thus lowering tuning and as long as u arent tune to 30hz or lower, u shouldnt notice much
and if you do its in the higher frequencies, but u will have a smoother rollof into ur midbass
edit* - i hate when three of us answer at once the same answer lol
Edited by decafcappucino
Thanks SPL2K and everyone else, appreciate it.
  • Who's Online   1 Member, 0 Anonymous, 2145 Guests (See full list)
